EVO Enforcer 2.5" lift questions on JL
epriev
So I have received all the boxes for the stage 4 overland enforcer kit. I was hyped to install it this weekend after watch the rancho lift install video. But then I read through the EVO instructions and got cold feet and I stalled the front bumper and winch instead. And needing a 24mm wrench.
The front follows pretty well with Eddie's video, other than the additional overland bracket steps.
For the rear the instructions show installing a sway bar drop bracket to the frame. The kit has no such part, nor is it listed in the parts list. I can't find one on the EVO website. How necessary is dropping the swaybar?
With only a 2.5" lift, would it be necessary to reroute the parking brake lines, or would they be fine as is. Do you even need disconnect the parking brakes for the 2.5" lift if you are not rerouting the lines?
I also didn't get the rear track bars. The stock should be fine? Does it need or can it be adjusted for proper alignment.
Since the stock rear sway bar links are relocated to the front, could you do the rear 1st? It seems simpler than the front other than hoping you get lucky blindly treading the flag nut on the passenger control arm.
Also, it seems as though it could be driven with just the rear installed, and do the front on another day.
Control arm jam nuts. It says to torque them to 250 or 300 lb.ft. after alignment. Really?
And the final setup instruction say to use a driver's side coil seat on the passenger side if a passenger side ARC is present? What does this mean? Is this the front or rear or both? I didn't see this in any of Eddie's videos.
Thanks in advance.
Eddie, your videos and guides are awesome. The rear lift went on so much faster.
On the passenger rear uca frame bolt, I use needle nosed pliers on the flag nut to get the spacing correct. Then lined it up looking through the frame ond uca before feeding the bolt to it. Took a few tries, but it seemed like a better option after trying blind fishing on the driver's side before I gave up and used the window.
I'll tackle the trackbar another day. And try the overland kit again later.
Upvote 0
Still looks low in the back.
Also what would this cost to install and alignment? Offroad Warehouse/4 wheel parts quoted $1200 plus tax & shop fees.
Took it for a quick drive around the hood. We have a road with very aggressive speedbumps and I didnt hear any unusual noises or binding.
Steering wheel is off maybe 5-10 degrees, but zero warning lights.
Upvote 0
steering wheel is an easy job to straighten out.
Upvote 0
I only charge $500 for the info. I’ll PM you my address so you can send the check.
Upvote 0
my shops labor rate is $160/hr and i believe we charge 8 hrs for the AEV lifts we normally install w/ geo brackets. Then an "alignment" to center the steering wheel.
Upvote 0
The JL always looks low in the back because of the fender design. Mine does, but it is actually level. Measure from flat ground to the front/back of the pinch seam, or use a level on it while parked on a level surface.
Upvote 0
After 3 moderate to hard trails around Idaho Springs, CO, it wheels close to the Xterra, but better, even with smaller tires. The automatic transmission is so much more controllable over rocks.
After the 1st trip, I installed the tazer mini. I was getting a bit annoyed with how long the lockers took to engage, but with the tazer, they seem to engage almost immediately.
On the last trip, dinged each wheel, both rear shock mounts and the driver side drop bracket as well as sliding on the front driver LCA. I go slow in these rock fields, so no huge bangs, just light thuds and scrapes. Also seeing how exposed the oil pan was, I think a skid plate is needed for it.
I kept wondering why I was hitting the rear differential until I inspected underneath while airing up. I didn't hit the diff, but the rear shock mounts. How durable are these low hanging mounts? Should I get the skids for them? I need to adjust since the previous truck had the shocks mounted higher on the axle.
Poser picture on Old Fall River Road in Rocky Mountain National Park. A 2wd dirt road I take my WRX on.
Upvote 0
The never ending J.E.E.P. journey.
After the 37s, I think I want a bit more lift as it has settled about a 1/2".
Looking at the EVO parts list, it looks like all that is needed is the longer springs, bump stops, and the rear track bar bracket or adjustable track bar to go from the 2.5" to 3.5 or 4 5".
Not listed differently, but likely needed would be longer sway bar links. And rerouting the e-brake lines.
But should I also upgrade the knuckles, steering and ball joints?
The Rock Jock high steer kit Eddie had a video on looks very doable.
Upvote 0
This list of things required to make up for 1/2" of spring settling seems long, and intense. Much more effort than adding 1/2" spacers under the springs! 😄
Upvote 0
If you want only a 1/2” more just get a spacer and toss it in there.
It would be more than the 1/2" settlement. Looking for a bit more height and travel.
So, with the EVO lift kit, just confirming changing the springs is all that really is needed. Not sure why different bump stops would be needed.
Upvote 0
