bobfriesenhahn
Expected!Coming from the resident smartass, seems like an appropriate response.
Compressors create heat, and so there is more to compression than just a strong motor. It is necessary to get rid of the heat. It is unlikely the double has twice the heat dissipation capacity of the single.I have a twin now, and I must say it’s meh. Was expecting a lot more out of it having run singles for years. Maybe when i have some money burning a hole in my pocket I’ll check out the brushless but not sure I’d ever recommend the twin over the single either, and the cost increase and space it takes up just makes it’s just ok with the rate my tires inflate
Stop talking.Compressors create heat, and so there is more to compression than just a strong motor. It is necessary to get rid of the heat. It is unlikely the double has twice the heat dissipation capacity of the single.
Stop talking.
Ideal gas law - Wikipedia
en.wikipedia.org
You just say shit and have no idea what you are talking about.![]()
en.wikipedia.org
the double is 2 singles, so.....Compressors create heat, and so there is more to compression than just a strong motor. It is necessary to get rid of the heat. It is unlikely the double has twice the heat dissipation capacity of the single.
Sorry, this is just basic high school physics. Get a grip!You just say shit and have no idea what you are talking about.
It’s two singles running together. You are retarded.Sorry, this is just basic high school physics. Get a grip!
The equation includes volume (e.g. pump compression initial and compressed cylinder volume, and tire volume), temperature (e.g temperature while initially compressing, and final ambient in the tire, which should be similar to the temperature outside of the tire). It should be obvious to anyone that the excess heat needs to be expelled by the pump and the tire. If the final temperature is not the ambient temperature, then the tire pressure will reduce while in use as the air cools. A better pump will get rid of more heat by itself (upon initial compression) so it is not left to the tire to do so. This requires more cooling area in the pump (e.g. bigger cooling fins).
To express in terms you may understand: "size matters".
Good to know. The new compressors are said to be more powerful and produce more CFM. To produce a similar ratio between motor power and CFM, the compressor cooling would need to increase accordingly.It’s two singles running together. You are retarded.
they are also brushless so less heatGood to know. The new compressors are said to be more powerful and produce more CFM. To produce a similar ratio between motor power and CFM, the compressor cooling would need to increase accordingly.
Curious why the compressor is running so much while you’re in the jeep?Anyone running this mount location for their compressor? Love it? Hate it? I probably should have asked before I hit the order button this morning but the noise from running the compressor inside the Jeep finally caught up with me today.
AAL Air Compressor Mount
Inclement weather while off roading. I have my wife and kid with me usually.Curious why the compressor is running so much while you’re in the jeep?
Makes sense. Sell the compressor you have and buy a portable. You’ll be money ahead.Inclement weather while off roading. I have my wife and kid with me usually.
