2024 JLR - CV Axle Shafts
So, if there is discussion on this, please feel free to merge, but I have not found a lot of experience / input so far.
We bought my wife’s 2024 Rubicon last year. Bright White, 2-Door, 3.6, 4:1 Part Time T-case, no e-torque, full float rear axle design. Definitely had everything we wanted. However, we have CV joints at the front hubs.
My question is why would jeep do this, and has anyone run this setup for a while?
I used to wheel with a friend in an early 2000s 4Runner and he used to wear out his CVs on his IFS a few times a year. Obviously a very different setup on IFS, but are CVs inherently more prone to wearing out?
CV’s on a solid axle not near as bad as IFS.
People pay big money for RCV axle’s.
I’d drive the shit out of it.
That's because on an IFS, the shafts are always operating at an angle and the CV boots are always in a semi-state of pinch. That pinch is what causes the boots to wear out. Lift your rig and this pinch is even greater and will cause the boot to fail even sooner. Same is true of the boot on the drive shaft rzeppa joints. Lift your Jeep and the front is in a constant state of pinch and that's why it fails so quickly (assuming you don't have FAD). On a 2-door, the same is true on the rear shaft.
Cv’s bind at extreme angles in an ifs suspension. That’s why they fail when you lift them and wheel them. In a solid axle even at full lock you are well within the working limit of the joint
This makes absolute sense.
I’m tracking you, here. It’s all about the misalignment factor.
I’m not a pussy… 😢 🤣
I can pretty much vouch for this.😆
LOL - CVs are very strong and RCVs are way bigger than the OE ones that come on Jeeps now. They're just really expensive and not really needed.
Agreed. However, in my case I’m a little gun shy as I have broken two u-joints. One wasn’t my fault as it was defective, but the other was alcohol induced. Lesson was learned that day. 😂 The deal was too good to pass up and now I don’t have to worry about being “that guy” on the trail… as much. Haha
LOL - just gonna say, EVERYTHING breaks.
They seemed plenty strong on my JL392. I was running 37s and wheeled a lot from Moab to Windrock without any issues from them.
I didnt shy away from hitting harder trails with them either.
No one learns a lesson while drunk the first time. No one. 😀
I have the CVs in my Gladiator. Jeep originally put them in for the 392 full time tcase and the tcase with 4 auto like my Gladiator.
Ever since Covid supply chain issues, Stellantis started throwing whatever they have available in to vehicles. My guess is now they have a bunch of parts and are getting rid of them. You have axle housings with the fad housing but no fad inside.
All of that to say I have had no problems with my cvs.
