Thirty7s
Last week I finished up the install of a new Clayton 3.5" lift, 1 ton steering kit, ball joints, and upper/lower track bar brackets on my 2017 JKU Rubicon. All control arms and both front and rear track bar are adjustable. Even after alignment and caster set to 4.2 degrees, the jeep drives horrible.
A little history......I bought the jeep used from a private party in Vegas and drove it back to Arizona. It already had a AEV 3.5" lift installed and stock control arms with the AEV drop down brackets. It actually drove really good and I was surprised how well it drove on the way home. After a few months, it developed some death wobble and that's when I started looking at the front end and the geometry of all the components. I quickly discovered the ball joints and track bar bushings were wore out. So I decided to install a new, better adjustable lift and replace all of the worn out stuff.
My hopes were that my jeep would drive and ride even better than when I first bought it. It rides a lot better and the new Clayton lift was a nice upgrade from the AEV, but it drives terrible now. It feels very unstable and darty. I aligned everything at home, (as explained here on this forum) and its near perfect as far as thrust angle, track bar adjustment, toe, caster etc. I took it to an alignment shop just to verify everything and he said it was near perfect and didn't need any other adjustments. The mechanic said I just need to "get used to how it drives" and "that's how lifted jeeps drive". I guess I'm confused because it drove and handled better before all of this work with stock control arms and track bar (until it started the death wobble).
Is there something I'm missing? Should I increase the caster a little more? Should I re-install the AEV drop down brackets even though I have adjustable CAs? That's really the only thing that changed geometry-wise that I can think of
Thanks for any input!
