AZVAJKU
Today was a beautiful day and with all the 392 talk I decided to do some mods on my 392.
My lovely wife rolls her eyes when I say I’m keeping my mods to a bare minimum on the 392 and I am committed to that. The first mod is going to be some stiffer springs. I do think the ride is a bit soft in the 392 especially considering how much power it has. I do not want or need more lift I only want a firmer ride. I believe I can accomplish that with some better tires and heavier springs.
First the springs. I bought a set of 4 Clayton Off-road springs. I installed these same springs on the front of the Gladiator and we have been very happy with them. The ride is much better and it took a bit of the ’rake’ out of it and it sits more level from front to rear.
The 392 will get a set of 4 springs, although I only had time to install the fronts today.
I measured the height with the stock springs.
Taking off the old springs. There are a couple of brackets routing important items That must be removed before you let the axle droop enough to pull the strings out.
Unbolting the sway bar. This is where I realize most of my tools are in my JK! I guess I need to buy more tools!
New springs in place.
Let’s see how much taller it is with the new springs.
So it does sit taller by a bit, however once I bolt on a Warn Winch it would be about right.
We took it out for a spin and it definitely has less roll and a much firmer ride- this with only the front Clayton springs installed. So far I am very happy with the results.
