Jackboeker83
I just got the Jeep back from the second shop and noticed my springs have been rubbing against the support brace. Not sure if it happened due to improper setup from the first shop, while flexing, driving around town or this is normal. I do hear so light metal on metal when I hit a pot hole or something but I figured it was my king air bump. I placed some tape on the spring to see if it rubs through the tape and if it does then it’s still doing it. I don’t care about how it looks I just want it set up right. If it is still rubbing should I grind the support brace down a bit to give clearance? I haven’t measured it but there not a lot of room between the support brace and the springs. I have provided some pictures to show the paint coming off the springs from the outside (the inside are a lot worse) but couldn’t get the phone in the tight space to show when they are close to the support brace.
