Umm it definitely should.I have the Tazer, but as far as I've found out so far, Tazer won't let me read or clear DTC codes so I'm looking for a way to do that.
Some codes you have to drive to clear, they will continually retrigger until the module they are reporting through (like the ABS module) determines the problem no longer exists. After my axle swap my steering wheel was waay out of center and I eventually got an ABS and traction control lights doing a quick test drive. no matter how many times I cleared with Tazer they were there. I had to adjust my drag link and then drive it for about a mile before the lights and codes went away for good. There's one code for sure and maybe 2 that are caused by the Tazer itself. Don't get too hung up on a couple of codes if everything is working good and you've got no warnings on your dash. I get a code everytime I accidentally bump the fog light button because that bumper and fogs are gone, I'm over clearing it. Try clearing them again, make sure you didn't sever a wheel speed sensor and make sure your steering wheel is straight first, do the stupid sleep cycle hokey pokey and then take it for a little drive. It might not clear all of them but I bet it'll clear a couple. One of those codes has to do with the TC, has to do with a selection of Rubicon or non Rubicon TC. I have a sport and that Tazer selection is defaulted to Rubicon, I think that's why I have that code. It doesn't really matter though as my TC works fine and I get no dash lights. Like I said, try driving it a bit, if everything is still going crazy you most likely still have something broken (like a wheel speed sensor for instance).@Disciple Off Road
I did clear all codes, did the full reboot, waited the time,
Then two cycles of : turned ignition off, opened door slowly then closed it, waited for the dash to go dark, counted to 60, turned ignition on without foot on break, let the codes finish dinging... REPEAT
It seems like it's rethrowing the codes
I get the following:
PTS U0415-00
DASM Module No Response
DTCM UO415-00
ABS C0031-1D
BCM U1514-87
PCM UO418 and U1409
Going to look these up now. I'm wondering if it is rethrowing codes or of these are deeper codes that are not cleared by the Tazer
FAD is Front Axle DisconnetWhat's a FAD, you need some wantons broh.
I know buddy, it was a joke, I'm trying to talk you into buying some one ton axles. Looks like you use your rig hard enough to warrant them.FAD is Front Axle Disconnet
I have Fusion 4x4 axles on order, but still 9 weeks out. I got the Fusion Elite Kingpin 60 / 80 set. Can't wait to get those axles installed. In the mean time, I really want to get my rig back in working condition. 9 weeks without wheeling would have me thinking about surfing 100' waves and other ways to die.I know buddy, it was a joke, I'm trying to talk you into buying some one ton axles. Looks like you use your rig hard enough to warrant them.
That’s pretty awesome actually.View attachment 389682
If you’re looking for other ways to die, I have a few suggestions…
