grungepup
So I will start with what go me to this point.  I just installed a new set of 33's on my Jeep yesterday, wheels are 17x 9.5 -18.  Everything was driving normal.  At the recommendation of the tire shop, I took it in for an alignment because my previous tires showed signs of inner wear.  Took it to a local chain (Brakecheck) to have them do a quick alignment. (I should have done it myself, but my work space is currently filled with my 325i im working on but that's another story).  After about an hour, the tech comes out and tells me that they are unable to complete the alignment because the tie rod adjustment screw won't budge. When I get it back, the steering wheel is now cocked to the left , enough so that my BAS and traction lights come on. I didn't have time when i got it home to mess with it.  When I finally got underneath it, I noticed why the adjustment nut wasn't moving, it's already maxed out. GRRRR.  While i was loosening the lock down nut, I noticed that the tie rods are shot, very little effort and the whole assembly moves. If I twist it up and leave it there, it will gradually untwist back to "neutral".  When I checked the drag link ( I didn't fix the steering wheel yet because I was running out of day light) it's just as loose. So I know I have to replace both the drag link and the tie rod assembly, but my question is, is it really worth the extra $500-600 to upgrade to an HD setup?   Looking around I found the teraflex for about $970 and the metalcloak for $730, and there were others in the middle range of the two.   I don't plan on doing any aggressive off road driving in the coming future, mainly just overlanding. Is it needed to tackle that upgrade now? or am I able to push that upgrade down the road when I plan to install adjustable control arms, track bars and lift?
TLDR: is upgrading tie rods and drag link needed
