how do you get it out. What am I missing
A Sawzall and grinder.Got console loose and card holder out in front , how do you get it out. What am I missing , View attachment 363638
^^ This. I’ve only done this once and it sucked balls. If memory serves, the E-Brake really made it a PITA. Pretty sure you need to shift the transfer case and transmission for more clearance.Did you remove ALL the bolts on the back of the console?
It broke in 4 lowYes, the Tcase needs to be in 4 low to get in off.
YesLol, you mean the part where you lose your shit and start pulling and yanking on everything?
Mine is a 2014 so the console is different, but I've never attempted to take the console out without taking the seats out. It's not 100% necessary, but taking the seats out is easy enough that I'd do that as well. Gives you room to twist the thing around enough to figure out how it comes off.
Not that it helps now but I cut an access so that I didn’t need to remove my console, would have been nice to have a factory access point.How do you fignal the plastic around the brake , if I take the dash face off will the give clearance or is there something I am missing all bolts lose I can lift it up gets stuck in brake , @#$@ any way no mater how you adjust , seats still in that should not make a difference brake how around the break ?
		I took it out once and it was a pain in the keister had to replace that wonderful plastic bushing a second time so I cut an access panelNot that it helps now but I cut an access so that I didn’t need to remove my console, would have been nice to have a factory access point.
