Suspension Direct
E-CLIK ($3299)
Rocker-switch activated three-level adjustment with independent front/rear settings.
E-CLIK ACTIVE ($4299)
12 independent sensors calculate movements and inputs, sending messages to the SDi ECU 250 times per second, automatically adjusting compression circuits on each shock, independently, based on real-time terrain and driving conditions. This is the fastest adjustment time in the industry.
Patent-pending E-valve proportional valve provides near-instant data-led setting changes.
Includes in-cab Touch Screen Controller with three modes to adjust base shock settings.
- Road – Prioritizes composure – More damping for a composed ride and excellent feedback to the driver. More sensitive to driver inputs: braking, throttle, steering.
 - Trail – Prioritizes comfort – Less damping for a more comfortable ride. More sensitive to vehicle pitch and roll.
 - Manual – Allows the driver to select the front and rear shock settings and disables the system from making automatic adjustments.
E-CLIK PRO ($4999)
Includes all the features of E-CLIK ACTIVE, plus our patent pending PRO menu, an upgrade that allows shock adjustment sensitivity to be tuned in the 5 following areas:
- Pitch Sensitivity
 - Roll Sensitivity
 - Turn Sensitivity
 - Throttle Sensitivity
 - Brake Sensitivity
