doubletapdaddy
It's much more prominent when you watch it in person, and to be completely honest I couldn't tell if it was an illusion or really moving / flexing. Hoping somebody else can take a look and let me know what they think.
That moves quite a bit. If it moves like that from the beginning then it shouldn’t be the cause, right? Did the JT move like that?
Someone should check the JK for similar flex...
Maybe I’m not viewing the video correctly, but it looks like if there’s flex at the steering gear, it’s not at the sector shaft, which is where I’d expect to see it.
That was my original thought but Mel was having DW on the JL/JT Experience and he's running UD60's with cast knuckles.
Ball joints are definitely suspect for me especially being that Dynatrac recycled the ones from our factory front axle and had a HELL of a time getting them installed. We have about 45,000 miles on them now so it wouldn't surprise me in the least if they're bad. I'm currently waiting for Synergy to release the ones they are making.
While searching for unusual movement, loose/worn components and over the summer, I noticed that the aluminum steering box appears to either flex on itself and/or on the frame. I checked the steering box bolts and they were properly torqued.
While checking out a friend's JT at the local dealership, I climbed under a brand new stock JTR (not my friend's) and a stock JLUR while a salesman turned to the wheels side to side. I saw the exact same flexing, so I figured it was just normal. However, in light of this thread I thought that I'd brave the 7° weather and go shoot some video.
In both videos the tires are on the ground (hence the squeaking in the first video) therefore there is some movement of the frame. However, I would assume that the steering box should move in concert with the frame.
Steering box. The arrow indicates the portion that was filmed from below.
This is the view from underneath, with an arrow to indicate the same part of the steering box that you will see in the videos.
EDIT: the videos came out weird in this post, so here are two links direct to the videos.
https://youtu.be/I4Fis5Mk1jg
https://youtu.be/4F16xoGckEw
Synergy makes a sector shaft brace for the JL/JT. Maybe plunk down a couple of hundred bucks and see if it helps.
Well I have the latest AE Mopar recalled stabilizer and I removed it tonight and installed a new junky RC stabilizer and I’m pleased to say the DW is gone. Now to figure out the real problem. I ordered a synergy brace and will install the new pump and report back. The RC stabilizer is way tighter then the factory one. Just another mask to the real issue.
