Pretty successful day despite everything else, non-Jeep related, that was going on. I woke up to my wife telling me there was a 100+ year old upright grand piano, for free, in Bisbee. Called the owner, got the trailer ready and called in reinforcements. Got it picked up and put in place at home. Brownie points earned with my darling wife and my 11 year-old daughter. Then it was off to the baseball field. After that, back home to do some painting and service the John Deere D160.
I planned on installing the Frankenstein 4” lift tomorrow, but I had some daylight and motivation, so I dove in. The front is mostly done. 4” Currie Rock Jock springs, Ruffstuff draglink flip and shock extensions installed. I still need to cut the OE trackbar bracket off and weld the new one on, align, adjust my sway bar links, torque and re-aim headlights. I’ll tackle the rear first, then get all that other stuff done after. I’ll also need to flex it out to check for bumpstop needs and if anything is stretched to far or binding, of course.
Spider in launch mode! [emoji23]
I realized two things after I had the front back on the ground. 1) I inadvertently left the .75” spacer in, resulting in a measured height of 23.25”, or 4.75” over stock and 2) I should have done the spark plugs first! Now I’ll need a bigger step ladder to reach! [emoji1787]
I actually like the look of the front,  A LOT! I can’t wait to see it on the ground with the rear springs installed! [emoji1303]
