Punisher417
Looks good! :thumb:
What mount are you using for your reservoir body?
Idk I had ORE do the install
Looks good! :thumb:
You didn't ask for that? Can you take a closet pic when you get a chance?
Those are some sexy shocks right there! Looks great :thumb:
MTG, I'm pretty sure KING is shipping the rear shocks that way now.. I have seen them that way a few times now.
If you move your compressor into the back or something post some pictures, sounds like a good idea. For now I'm leaving mine under the hood.
Cool. What is it though? Metal? Plastic? Rubber?
I like how easy mine was to fix. But if there is something more durable I might look into replacing the hose clamps.
It will probably be a while till I feel the need to move it. I just feel like it could possibly work better in the back seeing as it gets hot on its own from working, but already being hot cant help it im sure. I also need to find a good source for the wire I will need to move it.
I'll let punisher chime in on the correct answer for that. They appear to be aluminum, similar to what fox is shipping out with their resi shocks.. I'm sure they are better quality tho! :brows:
Got the hood on.
What tank is that?Got my co2 tank mounted to the roll cage. Getting it filled tomorrow. Finished my cb install and made a custom mount for the gate. Having swr readings high all across the channels. Tried tuning e tip but no luck. Gotta figure this out...ugh
View attachment 29233View attachment 29232View attachment 29231View attachment 29230View attachment 29229
