While wheeling out in Moab during the recent Easter Jeep Safari, Cindy and I discovered a rather odd if not troubling issue with the JL Wrangler's new 8-speed automatic transmission. Specifically, if you're in 4LO and have your transmission shifted to "D" or drive, you may experience a momentary loss of power while attempting an obstacle that requires a bit of throttle. This can cause you to loose the momentum you were needing and allow you to fall off your line. The first time I saw this happen was on JeepFan's JL and on this obstacle.
I should note that I experienced this problem for myself while attempting a similar obstacle and I won't lie, it kind of spooked me. For a brief moment, it felt like my engine just cut out and for no good reason. Of course, the answer to this problem is to make sure you have your transmission shifted into the manual shift mode or what is also known as 'M-Gate'. Granted, it can be hard to remember at times especially when you're shifting into reverse and then back into drive again but so long as you're in M-Gate, this problem will not occur. Anyway, I know all this may seem obvious to some of you out there but it wasn't for me. Hopefully this information will be helpful to others.
