TRLJNKY
Thanks for the response. Ill give your theory of a 1/4" a try and see if it behaves better. You gave me what I was hoping for. A good start point. . I know some of you have this dialed to where 6 turns is about 1° or 1/4"Most alignment shops don't work on modified Jeeps which is why they probably told you it was fine. Most shops that adjust caster on other vehicles do so to correct a pulling symptom so they probably didn't even know how to help you.
As far as the # of turns, hard to say for sure, but I'm guessing you'll have to make them about 1/4" longer. Just do a little at a time and recheck. Also, make sure the arms stay the same length as each other each time you re-measure your caster angle.
