The issue with too much back spacing on a Yj is the tread will rub the leaf springs a hard turn. You could adjust the steering stops but that would limit turning radius. I'm running 15x10 with 4" back spacing and adjusted the stops a little. I still have good turning radius. Big factor also would be tire size and style. Bigger shoulder lugs, the more the contact will be against the springs.
