BlackKnight
So I'm having transmission issues going back to 20 K miles (the first CEL was starting in the wrong gear (6-speed automatic cannot start in the wrong gear, not possible), I'm currently at just over 82K). I dropped it this morning as now it's 1/3 of the time not shifting properly, and surging in between 4-5th gear and I get this back from the dealer...
"Well Mr. hood, you have an aftermarket front Dif cover that is leaking like a sieve, and we need to know who put your lift kit in? Also, the Transmission is throwing dozens of codes left and right, there is definitely something wrong, and it's not something that you would want to drive until it's fixed". I had a CEL the day I got back from vacation, then after 3 days it went away, I called the Stealership last week and today was the first opening as "my two master techs were already booked up and one is out next week on vacation".
One, I did my front diff at a local Jeep clubs Wrenchfest (there are two master mechanics in attendance when I did my changes) and it's a Poison Spyder with Lube locker gaskets. It has never leaked a drop, I know, I check it weekly. Second, the "lift" is a pair of leveling blocks (two-inch ones) in the front and I pointed that out to her.
The trans should be covered under warranty, However, it looks like they are going to try to get out of it because they are saying I've modified the drivetrain of the Jeep outside of OEM. This is not to mention that When I told them I had armored underneath with aftermarket skids (EVO Skids and HD Crossmember), they almost didn't want to even look at it. they asked if I modified the OEMs, and I didn't, just added more/better...
Finally, they want $650 to do a teardown, to see the condition of the transmission, and verify that the fluids aren't "fudge". If the fluids are fine then it sounds like they will cover it under warranty, else I'm out the $650 for a teardown, and then the money for a new trans...
The Dealer is a Jeep dealer here in Westborough MA where I bought it. Has anyone else local had any issues with them? What about other Stealerships??
Bob
Bob
