Safari 4xe
Hello Everyone
I am driving a JLU 4xe Sahara MY22 (registered 2023). For some reason I don’t have any usual failures nevertheless it seems that several suspension components like steering box, steering shaft, ball joints failed at 5000 miles with no off road driving. During the replacement of the above parts all 4 shocks found to be leaking.
By observing the part numbers (shocks) found that the factory had installed wrong shocks for the model.
Had to wait for 4 months for replacement new shocks arrived with correct numbers on the box kit and the same wrong part numbers for the shocks
In fact found after additional search that both numbers was for rear side
The “wrong”numbers shock numbers are the following rear shock 68509414AB front shock 68509422AB (this is rear shock part number most likely).
does any of you have this shocks installed? On a 4xe Sahara stock ?
