How are people running wires from the Gladiator bed to the front? Are you running them over the bed or somewhere else? I’m thinking of mounting some lights on my rack. Thanks for the info.
I hooked my fridge up back there and went above the passenger frame the whole way.
Below I circled the wire in green.
From the battery, there is a small opening between two plastic pieces where you can feed wire above the wheel liner and easily get to it underneath and then run it along the top of the frame above the gas tank with plenty of fastening points (only reason for 4 gauge here is because I also installed an inverter). I was able to run all of it above the frame/gas tank.
