Wiring Rubi e-locker to Switch Pros panel
Stegertime
Looking for some help on how to wire my new rubi axles into my Switch Pros panel.
I've searched the forum and read a couple of good write ups on wiring the locker to rocker switches, but since I don't have rocker switches, I'll admit I'm a bit confused.
I've also seen some back and forth on what gauge wire you need and not sure what the final verdict is. I am also unsure if I need to wire in fuses for it either.
Any help would be greatly appreciated. Below is a photo of the Switch Pros module under the hood that is connected to the battery with a large gauge wire and large fuse. The 8 red wires coming out of the harness are for each switch on the 8 panel touch pad.
I have the factory plugs that go into the axle for the locker, but it is cut right after that, there is a black and a yellow wire, I'm assuming black is ground.
Does anyone know how I would wire these up and what exactly I need to do it. Thank you very much in advance for the help!:blush:
Do you have a multi meter? If not pick one up. A digital one will tell you which lead is + and -. Also many other things, ohms, volts, open, shorted. They are worth the money. As far as you specific question, I cannot answer it.
On the 07s the 2 relays located just to the left of the battery controlled the lockers. There used to be a write up on tapping into these relays so that you could activate the lockers at any speed. You may want to do a search on project JK and JK forum for lockers mods to see if it's still there. I did this mod on my 07 before the ARBs went on, it worked great and was easy to do.
search on JK forum for Rubicon locker by-pass. The modification adds a switch that grounds out the relay engaging the locker at any speed. I'm not sure about using switch-pro for this as its a +power controller without a negative bus bar. I've found switch-pros tech support very good. I would review the mod and then call switch-pros for their ideas.
Ok thanks Ken. I have a '14 so I think it might be different but I'll check and give them a call thanks 👍🏻
