TANK
Picked up a set of Rigid SRM backup lights and mounting brackets from Northridge. Install went fine until it came to wiring up the switch using the wiring harness that came with the lights.
I have an a-pillar switch pod with contura v switches. I have all 4 switches #6 pins jumpered together and connected up to the dimmer wire. I also have all 4 switches #7 & #8 pins jumpered together and run a ground stud in the footwell.
Coming out of the harness relay there are three wires: a red, a black, and a blue. The red and black are a given, but the blue only exists exiting from the relay. Rigid also included a good length of white wire to connect to their 3 way switch and tap into the reverse lights. Obviously, I'm not using their switch and I haven't run the white wire as I don't want these lights tied into the stock reverse lights but just tied to a switch.
I've tried hooking up the red and blue to the switch and grounding the black but with no luck.
I'm hoping someone on here can help me out as I'm at a loss as to what I need to do to get these wired up and working off this switch. I've included the wiring for the contura v switch.
(I'll also note that the switch does work, the leads are connected up to the battery, and the in-line fuse is good.)
