Looks sweet where did u get it and how many things can you have hooked up at once ? What are you Hopkins up to this ?
Nice job and looks great!
You could always relocate it with out much problem maybe mount it closer to the battery I've seen some mounted behind the battery or even on the battery
Why not just keep it put and maybe you will luck out or try making a small bracket that will hold it up over the fender away from the battery and small piece of aluminum cud be bent by hand and drilled and screwed right in
Thanks much it took a lot of thinking of where I wanted it. Hopefully where I got it currently bolted it won't interfere with my future EVO bolt on coilover. I know there's front inner fender trimming involved and its close to that.
I don't think you'll have a problem with it there. If I didn't already have the Off Road Engineering setup, I would definitely give this one a hard look. :yup:
