jk12blk
I'm looking at adding some recovery gear for an upcoming trip. I have a lot to learn in terms of proper techniques, etc, so I thought I would view winching videos this morning. I ran across this simple video https://www.youtube.com/watch?v=0yPO77QEpqo and what seemed like a normal demo on winching, I was surprised to see how many errors this person "apparently" made. I've provided feedback from one YouTube viewer which I wanted to share for your edification as well. Of course you will have to watch the video to see why he responded his way. Anyway, I learned a few things today and maybe you will too.
feedback...
"Perry, here are some things I noticed which you should be aware of: 1. If you are going to have your winch controller hooked up while pulling the cable out it would be best that it be away from the cable/fairlead so it does not get tangled up in it. Really best not to plug it in until needed. 2. The red strap you removed from the hook is used to pull the cable out and keep your hands off the hook or wire. 3. Your tree strap is too short for the diameter of the tree and almost does not allow to connect to the shackles. 4. Your tree strap should be at the base of the tree, not 2+ feet above it - probably due to the inadequate length. 5. You are using screw-pin anchor shackles of the bow variety (bow shackles), not "D" rings. 6. When you attach your bow shackle to the tree strap the strap should be on the bow of the shackle and not the pin. 7. You always back your pin off 1/4-1/2 a turn to prevent it from bindind if an off-center load is placed on the shackle. 8. If you need to cross over your cable you step on it, don't step over it and certainly don't set up your rigging stratling it. 9. Remember to engage your clutch before winding in or nothing happens and there should always be tension on the cable when taking up the slack, not loose like demonstrated. 10. Your winch may have 8500lbs of pulling capacity, but not on the last layer of the drum with only 30 feet pulled out. 11. Pulley blocks, not snatch blocks, don't increase the pulling capacity of the winch. They use the mechanical advantage to halve the load. 12. Best to put the Jeep back in gear so it does not roll away when the winch clutch is disengaged. 13. When you hooked up the pulley block to the bow shackle you side loaded it - something you should not do, but was probably done due to the strap being too short. 14. Alway screw the shackle pin down and not up so that the pin can't fall out. 15. I would do this over."
feedback...
