So I'm about to install a new winch bumper and winch, combined they weigh roughly 200 pounds. I'm just on stock suspension with no lift, will adding the extra weight to the front end cause any problems?
It'll cause your front end to sag about 1/2"-3/4". Installing coil spacers of that height will help to level you out. Aside from that, you should be good.
I installed the EVO 1/4 pounder with stinger and a warm 9.5ti winch. I then installed 1.75" front spacers on my factory suspension. With all that weight and the built in factory rake there's still a TINY bit of nose down rake remaining. No one but I notice it.
Edit: my winch has the steel cable so if you run synthetic it won't weigh quite as much
