LOL!
I should've taken a photo...It'll motor right along till he tries to turn. It's the turn radius that'll suck if you try to go super wide.
Also, was he on stock wheels? Backspacing will be a determining factor.
What's the widest tire you can run on a JK without spacers or lift?
Was on beach today and saw a wrangler running wide tires that didn't appear to be lifted. Looked great! And motoring right along. I'm curious... liked the look.
Now for a serious answer, the widest tires you can run stock without spacer or even new wheels and not rub would be a 10.5" wide tire. A 12.5" wide tire will rub at full lock unless you adjust your steer stops or run spacer
Stack 3 sets of these baby's together and you should be able to run at least 15.5s. If you want to go wider simply add more spacers.View attachment 259046
Difficult to tell...I hope there is sarcasm in your post.
