Pretty Fly
Hear me out here. All of the aftermarket driveshafts for JK's seem to be double cardan on the transfer case side and single at the axle. This type of drive shaft requires us to point the pinion in line with the drive shaft as much as possible. On the front this means sacrificing caster to keep the drive shaft from vibrating. On the rear, we end up bowing the coils if we aim the pinion up. I know there are solutions to these problems but would it not be simpler to run single u-joints at both ends of the shaft and split the angle difference between both ends the way this type of driveshaft is supposed to operate? Say 5 degrees or so at each end. I did some research on the double cardan shaft and I read that it doesn't even allow much more maximum angle than a single. I'm tempted to have shafts custom made. Thoughts? In case you haven't seen this before, I thought this video was great.
http://youtu.be/gmV4qwLfOMY
