Which PSC kit
Atch
Which PSC hydro assist kit is everyone running? I've been researching these kits after shearing off my sector shaft. I've seen the extreme duty PSC SK-260 or the trail & street kit PSC SK-255. By the descriptions online it looks like the trail & street is the way to go but I'd appreciate some real world experiences.
I have the extreme duty kit! The only difference is the bore size of the ram assit. Slightly bigger on the extreme duty. My vote goes to the extreme duty kit! :thumb::yup:
Go extreme duty. That's what I have. If you ever go more than 37s you will need it. Only diff vs trail and street is that with extreme, your steering on the road will feel more sensitive/tight.
Extreme duty...
Like the others, I run the extreme. But I have the extreme duty for after market axles, which is designed to be a weld on application for the ram assist brackets.
i had the same question when i sheared off my sector shaft back in the spring. They don't offer the trail&street version anymore so that makes the decision easy. Extreme Duty
Could save some cash by tapping your steer gear,buying a ram from anywhere then add psc high volume pump kit and your set
