This is drawing from personal experience of having the jeeps safety devices nearly causing me to flop the jeep over on its side. In a rented 2012 manual trans jeep, I was climbing up towards the top of a loose dirt/rock hill in 2wd. I figured once it broke traction I'd stop and shift it into 4low. Well, the moment I lost traction and stopped moving forward, I went to hit the brakes and clutch. At that moment the jeep rolled backwards maybe 6 inches. The immediate backwards momentum triggered the ABS system (still in 2wd) and I could NOT stop the jeep from rolling backwards on the loose dirt hill. Now I'm going backwards down the steep hill, picking up speed, unable to stop. I thought I was going to break off the brake pedal because I was pushing it so hard. Now the jeep is going backwards, and I'm panicking trying to stop it. If I had it in 4low, the ESP and ABS are switched off and I would've just skidded to a stop. Not in 2wd though!! Some how, I made it backwards to the bottom of the hill where it flattened out. The sides of the road were built up so if I had went towards either side, I'd have dumped the jeep over for sure. I will NEVER not be in either 4hi or 4low again while screwing around off road. Lesson learned the hard way...[emoji106]
Sent from my iPhone using
WAYALIFE mobile app
