IronWorker18
Hey all,
Just did an axel swap of the rear driver on my 08 rubi jku. Went with Yukon and pressed everything together myself.
I did it using the wayalife install and removal write up which helped tons. I bought a cheap press to do the abs ring and bearing collor and was having too much of a pain in the ass to try to press the wheel lugs in with my press . I figured I would just pull them through using metal wheel studs with no Cap on the end + old rotor.
They aren't pulling in tight and I'm starting to strip the lug nut. I'm now using a tap and die set to get the threads back
Ok.
Where did I go wrong?
Ok.
