Wheel clearance
JWasko
Perhaps not so much a question, but looking for affirmation. Currently running 315 70 17 Nitto Ridge Grapplers on stock Sport wheels 17 x 7.5 with wheel spacers to prevent any rubbing with the LCAs. If I go to a 17 x 9 wheel with -12 backspacing, that should be enough to clear everything without using the spacers, eh?
I think you're confusing offset with back spacing. 6.25" of back spacing is what a factory wheel has and what you want is a new wheel with no more than 5.5" of back spacing. That will clear things without spacers.
Upvote 0
You are most correct Sir. Went back and looked at the specs and back spacing is 4.50 for the wheel described above. Appreciate the clarification. And a good day to you Sir.
Upvote 0
