Thank you do you know how hard they are to replace?Yup, cowl corner or something along those lines. They get dented pretty easily from a gust of wind if the door strap isn't in place. One of the first mods I did was to put cowl covers on to prevent that.
Hmm alright doesnt sound to difficult thank you.Not sure about on a TJ but on a JK you have to take off the wipers and then there's about 4 or so torques bit bolts to remove and then it's spot welded to the front quarter panel. So to replace it you'd have to drill out the spot welds and either spot weld or use self tapping screws to attach the new one. Not hard at all just a little time consuming. I had to do this when I installed my fender armor up front as it reused the cowl corners.
jeep life
My drivers door swung open and the mirror left a nice dent in mine. Stupid mistake.
Glad it's not too hard to replace.
By the time you have dug in far enough to take them out, why not just pop the dent out? Mine has one on rhe drivers side from the PO, but I havent felt the need to fix it yet, however popping it out was my path.
Though the one the OP has is far worse than the usual mirror dent of the JK.
Sent from my SM-N910V using WAYALIFE mobile app
