Wow! The chattering noise? Is it all gears or just one?
I've got a 2012 that I've got almost 8000 on now and haven't heard anything like that out of mine, sounds simple but to satisfy yourself crawl under and check for leaks and fluid level. Sometimes the manufacturers forget one, my mom had a new front diff put in her expedition cause they didn't fill it properly
That was one of the first things I did when I first got the noise. I have check it periodically and no leaks and level is fine. Even the dealership looked into the noise and they found nothing "abnormal" they said. Performance is not affected, it is just a noise that is hard to live with. Additionally I am afraid that after factory warranty runs out, the tranny falls out and I am stuck with cost.
I guess it could be considered a mod. :rock:
I've got a buddy that is a Chrysler service writer, I'll send him a text and get his thoughts on it
I have exactly the same sound as your third clip in my manual 2013 JKUR. It occurs in 2-4 gears right around 2000 rpm. I took it to the dealership and they told me they thought it was normal, but they also did not have another manual to compare it to. The are supposed to call me when they get another manual in. They will invite me in to test drive it together.
My problem is I have a window of opportunity to start my build, which is now. so today I started ripping things off and it will be on a lift for 2-4 weeks.
Dave
It may be different yes.. but it still sounds off... I just got back from a drive and I paid extra attention.. the only thing I hear is just a slight mesh whine.. you've got a definite chatter to yours, wouldn't think you'd have clutch chatter like that just driving but it could be something else to investigate....
The sound I have is similar to missing a cylinder, or like a two-stroke motor right around 2000 rpm.
Kinda sounds like it could be a bearing running loose too. I'm curious to hear what it actually is, be sure to post findings. Oh and good plan on not saying anything about previous efforts with that other dealership. There's all kinds of stories about differences between dealers...
