I've just done my second clutch in just over a year. I hardcore trip with lots of deep mud over the last week cooked the last throw out bearing and clutch. What's every body running ?
Really?? I suppose I'm just a mall crawler but I was able to get over 100,000 miles out of my factory clutch and only replaced it because I got a new motor and transmission with it. If I still had a manual, I personally would still be running a factory clutch but, that's just me.
80k on mine how she has that extra 20k left. But i agree after getting this far i think ill go stock replacement, maybe a different throw out bearing at that sound is annoying!
if you're playing a lot in deep mud it'll wear out your clutch components faster. if you're shifting in the mud or riding your clutch to keep it from stalling you'll burn your clutch out faster.
just replace it with stock, a more expensive clutch will not make it last long enough to be worth the extra expense if you play a lot in the mud.
you may be able to pull it apart, take some 200 grit or so sandpaper to the flywheel/clutch pad to remove the glazing caused by the mud. if the fingers and springs are still good, replace the throw out bearing and you may be able to get a little more life out of it.
http://project-jk.com/jeep-jk-tsb-r...ncorrect-pre-load-on-clutch-throw-out-bearing
I was curious if anyone has seen this or done this procedure. It says its for the 2007 JK, but all Jks are using the same manual trans I think. I have the squeak until I push the pedal in and it goes away so I'm hoping this procedure would work for me.
