Honestly, there's nothing better out there than a Dynatrac ProRock 44
Serg5000 said:Lets say I am using a Rubicon D-44 housing. What brand of internals would you recommend?
Locker?
Gear set?
Axle shafts?
Man I hope so.MTG said:kid only gets married once!
Serg5000 said:Man I hope so.
ChrisB said:Not your problem the second time around. Congrats!!!
Most after market will have full clips
wayoflife said:- ARB locker
- All the gears are made by the same manufacturer so to doesn't matter who you go with
- Any basic chromoly shafts will do the trick so long as you make sure to get them with full circle clips. I personally would wast your money on RCVs and would use the money you save to get a set if pro steer ball joints. A much better value.
One other question. Running 37's. would I be crazy not to sleeve? I already got my C-gussets and LCA skids. Before putting those on I wanted to see what you guys thought about sleeving.
wayoflife said:never ran sleeves on moby and not running any on rubicat now. they are cheap insurance but, far from necessary.
Trail_Creeper said:What did you use to get the metal shavings out of the tubes? Magnet?
That seems to be my only worry about putting the sleeves in at the house.
Trail_Creeper said:Did you pull the diff while doing this?
