Again I want to thank you for the info. and quick response . I don't like spending money where it is not needed either. The guy I know only wants $80 bucks for each factory shaft . I am going to pick them up either way I go ! That is what I call cheap insurance . Without looking it up , I probably just take the diff. cover off , remove the gearset , remove the c clips with the tires , and brakes already removed , and slide the shafts out , right ? I will have to get the tone rings removed from old and have them pressed onto new shafts , then reverse the install . I think I should be able to remove the gearset all together and put in back in without removing anything like shims .Does that sound about right ? anything I'm missing ? Thanks .
Whoa, "c-clips"? Just to make sure, you do have a JK right and these are shafts from a JK too? If so, if you have a Rubicon, you will need to make sure the shafts are from a Rubicon too as they are different spline counts and even lengths left to right. If you have an X, Sport or Sahara, you need to make sure the shafts come from one of those and, it won't matter what side you use as they will be the same.
Having said that. You don't need to open up your diff. You just need to do the following:
1. lift your Jeep up from the pumpkin and set your axle on jack stands.
2. Use a 19mm socket to remove your rear wheels.
3. Unplug your ABS lines.
4. Use a pair of vice grips to disconnect your e-brake cables.
5. Use an 18mm wrench to remove the 2 bolts securing your brake calipers - hang caliper with a bungie cord or zip tie.
6. Remove rotor.
7. Use an 18mm wrench to remove the 4 nuts securing the backing plate to the axle.
8. Pull out the axle shaft.
Assuming that the used shafts you're getting are the right ones, everything should still be pressed on and you should be able to just slide them in and re-assemble things.
