LIKEITHIGH
ok ill start by teling you whats on my jeep now. I have a 4 inch rough country lift ( which I wouldn't buy again if I had it to do over ), it came with new coil springs , shocks, extended brake lines, all upper and lower adjustable control arms front and back, rear coil spring angle correction brackets, front adjustable track bar, rear sway bar links,front quick disconnect sway bar links. and I also added a 4 inch drop pitman arm , a rear relocation bracket for the jks adjustable rear track bar, and a rugged ridge double caradine joint front driveshaft. heres my problems im having bad suspension problems. ill number the following topics and questions so it will be easier to number your answers to match with the topic you are referring to ( I hope its not to confusing to read, im not the best with words )
1) all 4 coil springs are bending at hard angles when the truck is sitting on level ground. when I took the rerar tires off and looked at it from driver side it looks like the axle needs to roll upward counterclockwise to me ,but im hoping adjusting my control arms might make this better.
2) does anyone know about what the angle of the axle should be with a 4 inch lift, if I put my Johnson pitch & angle locator on the bumb stop pads on top of the axle?
ill try adjustments after I post this thread.
3) the passengfer side of axle might be closer to the front of the jeep than driver side.
4) the rear sway bar end links are bent where they have hit the upper control arm mounting brackets on top of the axle. I figured this would happen though, cause after the lift was installed I noticed that there was only about a 1/4 of a inch of space betrween the links and mounting brackets. don't know why, maybe they sent me the wrong length rear end links or soething. looks like the rear sway bar would have to move back to work right.
5) I keep getting death wobble because my ftont track bar axle side bolt hole as somehow got bigger thanthe bolt mounting it to the axle brfacket. and if the rear gets a relocation bracket then why wouldn't the front. I didn't get one with my lift.
6) my font coil springs are bending toward the driverside for some reason.
7) my front sway bar links also look like they are leaning to the driverside. what can I adjust to make coils sit right?
8) I guess what I really want answered is what procedure can I follow to adjust my front and rear suspension to where they sit straight while keeping the axles centered under the jeep,
9) or if I cant adjust anything to fix this , then what parts orupgrades do I need to buy and install?
10) do I need a front track bar relocation bracket or one of those flip kits ( not sure what they do )
Ill try to upload some pictures when I have the tires off of the suspension for you to see, because im only sying everything looks wrong to me but I don't know what it should look like really.
THANK EVERYONE FOR ANY HELP
WINSTON RYMER
WINSTON RYMER
