livingwithcause
So recently I felt like my Jeep was getting out of alignment. Tire wear was off and it was pulling every so often. Took it in to a local tire and lube shop. Came back in and they said it was all in spec and good to go. I pull out of the drive from there and it feels a bit funny. But assumed it was just getting use to it being in actual alignment. Thus I drove it for a week. It is yanking me everywhere. Get home to check the alignment and you can see this from just looking from the top:
Way off and looks like some is shifted. So I run a line around both tires (holding a silver sharpie and spinning the wheels. Assuming one would cause like a spiral...it doesn't. So I measure from front of the tire (one the line I made) to the other tire's line. Move to the back and do the same and its only 1/4 of an inch wider on back....... so there is a toe in. I measure about 6 more times and its the same every time. So I measure inside the wheel well to solid points and the passenger side tire that looks off shows almost an 1.5 inch difference in toe than the driver side tire. Thinking I might have a warped wheel I spun and marked again and the line is straight as an arrow on both wheels. I'm lost.
Here is a front view too. Maybe I am measuring wrong. Who knows.
