Oh yea I don't have a buffer...
I always have that prob. Just did a wax a few hrs ago but it was to dark when I got done. I'll let you know if it worked tomorrow.
EVO 4G WAYALIFE.
Neither did Daniel-san when Mr. Miyagi told him to wax-on, wax-off...
once you figure out how to get the spots off there is two things you can do to prevent most of them from coming back the next time you wash it.
1. there are two soaps that are good to use if you have hard water or any high metals in your water. KarKraft cherrywash or Duragloss carwash.
both work excellent and help keep water spots from coming back.
2. double check the way you rinse her off, an old timer told me not to blast the hose, take the nozzle off and let it slowly rinse away. i thought he was
full of sh!t, but it has worked on my jeep and on other toys i have.
worth a shot, hope you can get them out.![]()
depending on how old the water spots are, I've used a 2-1 mix of vinegar/water in a spray bottle, spray the area with the spots and let it sit for about 10-15 minutes - don't let it dry! you can then take a clay bar with warm soapy water - I use Dawn, put some dawn direct on the wet clay bar and wash gently.
If the spots are really old and deeper you'll need to use a cutting compound, we used to use a product called Miracle Wax don't know if it's still around but there are several to chose from - McGuires comes to mind - make sure you use the appropriate pads with it.
wax and enjoy!
A lot of spots are created by calcium and vinegar will help to remove them.
Well the wax worked but I did have to use the karate kid method pretty vigorously. I used Meguiars Mirror glaze Hi-Tech yellow wax 26. I think next time I might try the vinegar and then wax.:yup:
it's a 2 step process, did you let it soak? and did you use white distilled vinegar?
Yea I let it soak for like 40 minutes and I use home make red wine vinegar lol
lol...well, distilled white vinegar has more acidic benefits but don't let it sit that long, it may cause more damage.
When washing the jeep I keep it completely wet the whole time. Then park it in the shade to towel dry as quickly as possible. This prevents the water spots from happening to begin with. When I have not done this and got the water spots, I rewash and do as stated. That seems to take care of it for me. :yup:
Side note: I use Lemon Pledge to wax my rig. Simply spray on small (2’x2’) areas and wipe off. I use it on the soft top also. :thumb:
