OC Paul
I picked up a used Powerplant and the systems keeps shutting down.
I used a jumper wire and bypassed the compressor pressure switch and now it works without shutting down from the bad switch.
My first question is..... On a properly functioning unit is it normal for the tank pressure release valve to open and bleed off excess pressure frequently?
Seems to me that it would be the case because the compressor is always running even when the unit is in winch mode....right?
My second question is.... Do you think I can run the powerplant with the jumper cable bypassing the compressor pressure switch without damaging the unit?
Seems like it would be ok... Am I missing anything?
I want to go wheeling in Big Bear this weekend and wont be able to get a replacement switch in time.
