Noble Woodsman
I know this is probably a dumb question, but I'm trying to understand how to properly size ujoints for a driveshaft after an axle upgrade. Should the ujoints on the front drive shaft be selected to match those on the new front axle shafts, or should they be one size smaller to allow failures to occur on the driveshaft ujoints instead of on parts that are more expensive or harder to repair in the field? I read somewhere that ujoints should be treated as the "fuse" in a driveline setup so that they would fail first. Is this correct? If the driveshaft ujoints are sized to match the front axle shaft ujoints, then would a driveline failure be more likely to cause damage to the transfer case and transmission?
To provide context, I'm planning an axle upgrade for my 2015 JKUR, and I'm strongly considering the Dynatrac Hard Core Plus XD60/XD60 axle package with ARB lockers and 4.88 gears. I plan to run 37" tires now and 40" tires later, and the use case is rock crawling. The entire drive train is currently stock. If I understand the Dynatrac website correctly, the XD60 uses 4140 series ujoints at the steering knuckles, and I presume the same size at the pinion yoke. Should I be looking for a driveshaft with 4140 series ujoints also (do they exist?), or should I step down to the 1350 ujoints for the driveshaft? Would the sizing for the rear driveshaft in this case be the same as for the front driveshaft?
Please go easy on me. I'm new to the forum and still in the planning stage on this build. Thanks!
