Solar Dude
Trying to give a buddy of mine good advice. He's got a 2015 JKU Sport with an automatic with 3.73 gears. He had the dealer install a 3.5" pro comp lift and 315/70-17's. He is also towing a somewhat large pop-up trailer, 2500lbs. As you can expect his towing performance is less than ideal, I finally talked him into getting new 4.56 gears. I recommended he install a new differential since he's getting the gears done. It's his DD and he isn't doing anything too radical yet but we are tossing around the idea of doing the Rubicon next year. With that said he's not going to throw down for air lockers, nor would he be thrilled about installing something that would negatively affect the JK's road manners like a full locker, I.E Detroit locker. My first question is how well does the factory limited slip work and is it worth re-installing? Second, has anyone here installed a truetrac in the front axle before? I had one in the rear of one of my service trucks and it worked great, no bad road manners or clunking or knocking. My idea was the best bang for the buck was to leave the factory limited slip in the rear and install a trutrac in the front. Or should he just shit can the factory limited slip and install the truetrac in back and leave the front open? For what it's worth we drive a lot in the snow here in the Sierra's too, so if the truetrac in the front would negatively affect that he probably wouldn't be happy.
