chttrbx
I have a small Transmission oil leak from the gasket on the Transmission Pan, and the Transmission lines look rather nasty and oil covered. I will be doing this in the very near future, need to know how to ID correct Tranny Fluid? And whether anyone has replaced transmission lines and what type of tool is used for the clamped ends? I have considered just replacing the flex tubing and using a hose clamp as a last resort.
Also, I broke/sheared off 2/3 blots for main skid, which appear to be spot welded on inside the frame, if you had the same issue, how did you resolve?
