So a number of months ago I noticed I had some fluid on the transmission bell housing, just behind my oil pan. I took it in and had the oil pan gasket replaced, which I thought solved my problem. However, it only solved half. I had to leave my jeep parked for a few days and noticed a small spot under this same area. Went back out and noticed a small bit of fluid again on the same housing. It appears to be pinkish in nature, which I'm assuming is transmission fluid.
So what I'm trying to determine is what could be causing this leak. The shop had to pull this cover to do the oil repair, did they not replace correctly? Could it be from the transmission? or from the lines? Let me know your thoughts.
Thanks,
Thanks,
