LGPow2006
I know search is my best friend. Specifics to the ambient heat and potential engine overheat associated with mounting a tranny cooler in front of the radiator.
I am in SE Arizona. Not as hot as Phx but triple digits are pretty common (and common soon I suspect). I have seen two types of coolers. 1 coil and fin type that mounts in front of radiator ( I assume) 2nd is more like a heat sink of billet that appears to be mountable any place there is an exchange of air.
I know about using lower gears to prevent the issue etc....I am very nervous about the up coming summer with no cooler and want to get one on soon..... Then comes the problem....will a radiator mounted aux cooler cause over heating issues with my coolant?
I see many people from the dessert on this forum so I am sure I will get great advice based on personal experiences....
09 Auto 2 door. Stock diff ad such.... 33 tires.... What else you need to know just ask
Thanks in advance
Thanks in advance
