Can anyone tell me if the Trailhawk takes off in 4 wheel then switches to just front? I have read in reviews that it launches in all wheel then changes to front!
Thank you
The Active Drive Low system that your Trailhawk utilizes works the exact same as the regular Active Drive system. On initial launch, the front and rear are both engaged. As you're driving it engages and disengages as the system sees fit. It will run in full front wheel drive when just cruising around, but the moment you plant your foot the rear axle disconnect system engages to maximize traction.
