Anyone tried and tested this? Ordered camera yesterday and am curious if the screen on TD is activated only when 12v is applied to camera? Either tied in to reverse light circuit or thru toggle for undercarriage view?
Your right on the flipped image, I did a quick temp hookup and the image is flipped when facing forward. It doesn't engage in reverse automatically though you need to touch "menu" then select camera. Not a big deal as long as your patient enough for screen to wake up before backing up. You can view image while driving also if you want.
Only downside is the traildash doesn't come with the accessory circuit output for camera power, so I'll pick that up somewhere else. Don't want full time 12v to camera.
My trail dash comes on automatically w reverse. Once signal gets power, it takes over traildash
How are you running the wiring for the power? Did you tap into the reverse light? I have to go through options to get it to pop up. Thanks
Mine is now coming on automatically with reverse or manually while driving. Im not sure about JKFlyer, but I picked up an accessary circuit so that camera has power whenever the key is on, not only when the reverse circuit heats up. I think the signal (when powered)is always transmitted from camera to TD, but only displays when in reverse or manual input.
Heres a pick from last trip while in manual mode, not in reverse.
Yes tapped in to rev light wire
Damn good idea. Need to do that ...but question...I thought if I did that it would power on my reverse light. Does it do that when u activate your switch?
Negative. The rev. circuit and the aux. ckt are electrically seperate so the lights arent affected by camera status and only work when supposed to.
