So I just received the trail dash I bought from forum member, I did the install, gear change and tire psi to 22, now I have the traction control and the ESP light on
Wen I try programming the octane performance in either of the options it's says Clearing the vehicle DCT, turn the ignition on with out turning on the vehicle, after I do it, then it says THE OPERATION FAILED
Have you updated the firmware from Superchips.com? Go to their website and download the fusion software. You'll need to reset your traildash back to stock before hooking it up to your computer. I haven't had that problem with mine but that is the first thing I would try. I just noticed you are set at 33" tires and 4.88 gears, is that correct?
