Traction Control Light Stays On
K.D.C.H
So in my 2015 JK sport the traction control light has just started to come on. The TC system itself is not engaged while the light is on, it's just the light that stays on.
It was on yesterday for about 15 to 20 minutes on a smooth and bump free road and then it automatically turned off. Last night it came back on and stayed on and now this morning as soon as I started the jeep and took it for a drive it stayed on as well.
Any ideas?
Any ideas?
Steering wheel straight? That's the biggest culprit.
Since it is just the TC light, I'd probably double check your steering wheel alignment like petey said. It doesn't take much misalignment to trip the light.
I had a wheel speed sensor wire get rubbed through, however, it caused the abs light to come on along with the TC light. Since your light comes and goes, I can't imagine it would be a hard failure like a broken wire.
Good luck!
Ok cool, it's a little off right now and was going to be on my list of things to do before this weekend lol. I'll check it out and post an update. Thanks Jason
After you straighten it up it may take a bit to go off but it should take care of it. :thumb:
Gotta love when your to do list keeps growing right before a trip! :) The good thing is straightening the wheel is quick fix!
Do you have a procal?
The Procal works great, however, to really do it right with the Procal, don't you really need swivel plates such as those found on an alignment rack? I tried using the Procal at home and fount it to be an unnecessary step. What worked really well for me was go for a drive, note where the steering wheel was when driving straight, then head back home. As I pulled jet the garage, I drive straight ahead with the steering wheel positioned at the noted position from the test drive. Then, I climbed under the Jeep and made the adjustment to the drag link until the wheel was straight. You might have to make one final tweak after another test drive, but then you should be spot on.
All of that said, a couple of months ago I got an alignment at Big-O. With the front tires on the swivel plates, we used the Procal to set the steering wheel to center and used the alignment machine to set the tires straight ahead. Worked like a champ and the tech loved it!
Good luck!
Thanks so much.
Sounds good. Thanks for the fast info
No kidding, hoping that's all it is lol
No but I have the Flashcal. My computers are all Macs do I need to find a PC to update and register it before I can tune the Jeep.
Usually takes me a couple tries. Center it, drive it then double check. Just asking if you had one. There is a feature to lower or shut off your tpms also.
Edit, I quoted the wrong guy.
You both have white jeeps. Please forgive me
I have a procal and do it this way every time.
It's OK, we won't hold it against you! :)
Mine is white too :D I probably should've stated that a little more clear in the original post. Hopefully doesn't change how people feel about me :cheesy:
I have one too, I lose track. But anyways, I don't know if flashcal has a feature like that
No I don't think it does
Not really needed, but nice feature. Just find a nice level parking lot, drive it and let the jeep go straight, if your wheel is off you'll notice. I have used masking tape on the top center of the wheel so I can see from the front. Makes it easier. 15 mm wrench and really easy to do.
Got it all taken are of. Centered the wheel and the light went away. Thanks everyone for your help. Now to get back to the rest of my to do list
Sweet, what other little things you have going on or planned?
