Tpms sensor stem broke
Dmac08JK
My new tire tpms sensor stem broke. So I went to the place I bought my tires from but they didn’t have any sensors in stocks. So they put a rubber valve stem. Will that ruin my sensors ? Could it hurt my tire or rim ?
You should be fine. I know on mine the sensor is part of the valve stem , so they would have to remove that to put the rubber one in. Your low tier light will just be on , till you have a new sensor installed
This ^^^^
I ran without any of the TPMS sensors on a set of tires, the low tire dash light was on but no issues
the sensor is attached to the valve stem via a torx screw. they make rubber stems that work just fine with oem sensors. If this is what they used you are ok. My guess if your tpms light is not on then this is what they used.
They just put a rubber stem in. The low tire light is on but I ordered a new sensor. Thanks for the help
Thanks for the help. Did you do anything mudding or drive in snow ?
other than the low tire indicator, it didn't affect the other systems.
I drove thru Colorado on my way to Utah and hit snow, no issues.
I don't purposely look for mud, I did once and spent way too much time cleaning up the mess lol
Awesome thanks. I don’t really look from muddy trails either but it’s close to my house.
