Toyo MT question
LAJK
I'm running 37x13.50r17 on my JKUR that weights a little under 5300lbs and was woundering if its more normal for the rear tire's to wear more then the front tire's? They have almost 32k miles and them and I just noticed this. Is this normal Or a rotation issue?image.jpg
I'm going to say rotation issue I'm running the same size tire and they all are wearing evenly.
Double check the load rating on the fronts compared to the rear. I was once sold a pair of D's and a pair of E's. And the D's wore much faster.
Toyo 13.50s are only made in E range. I vote rotation/inflation issue. Chalk Test are reevaluate your rotation schedule
your main drive tires will wear faster. if you haven't been rotating them regularly this will happen. have you not rotated them in 32000 km?
